Nbs Escalade brake light conversion help
adventurenali92
Big Bear Lake, ca
If you haven't already ordered a new light, don't! The wiring for some reason on the Tahoe and Yukon is backwards from the Escalade light. I just did this to my Denali XL a few weeks back. Reverse the wires and the light will come on just fine! That being said the base will fit if you use double-sided tape it just won't be all that flush. I also had trouble getting my third tail light to mold to the shape of my yukon's glass as the yukon and Escalade hatch glass are shaped differently up at the top under the trim. I ended up the swapping of the whole hatch to make it fit. And I'm glad I did as it fits much better and the screw holes lined up so I didn't have to use double-sided tape.
#1taho
5150TAHO
niagara falls ont
Mine was plug and play. 2002 escalade I got the parts from and mine is 2005. Maybe there is something in the newer years that make it different.
#1taho
5150TAHO
niagara falls ont
The lines match up fairly good
Side view looking back
Yea this is the esky glass
adventurenali92
Big Bear Lake, ca
@#1taho , I don't know why everyone says there's gaps. Lol. Everything on the back end of my Denali with the eksy parts match up totally fine and there's no unusual gaps. Interesting in the wiring. I'm not sure what year esky my third light came off of. But I had to switch the wires for my 2006. Maybe the Chevy and gmc wires are different. Wouldn't see why though. Anyways your setup looks great!
#1taho
5150TAHO
niagara falls ont
Thanks. The forum had an influence :devilfinger:hahaha.
If I remember correctly is was Fosscore that gave me the idea and helped me along.
kwOH
Banned
I know where an escalade glass and brake light is at, thinkin about gettin it, how hards the swap?
So I put on the vent corner caps. Pain to take out the old ones though! At the top corner the is a gap looks as if it was not seated correctly is this normal. Is it like this because of the third brake light on the escalades they line up?
I'd say those appliques (vent caps) aren't installed correctly; I have them on my Denali with the stock Denali rear glass and they fit perfect.
img_5624-jpg.66417
LOWHOE775
LOWHOE775
Sparks,Nevada
I will try to switch the wires around tonight thanks for the heads up.
LOWHOE775
LOWHOE775
Sparks,Nevada
The lines match up fairly good View attachment 66699 View attachment 66700 Side view looking back
Your lines are perfect I am going to try and see how it looks with double sided tape first if it pops out too much I'll just get glass of an escalade and call it good
bd928
