Need help on installing a DD unit in my 04 tahoe
denalianyone
NYBlackLade08
New York
I hooked mines up to the light green wire in the A-pillar on the driver side. The lt green is located in the rearview mirror as well.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I forgot about gentex mirrors using reverse signal to disable the dimming!
Good catch.
V
vatahoelt
NoVa
great, thanks for the help. i'll check the A-pillar for the wire. can't wait to finally get this thing in.
JKmotorsports
Austin, TX
I was going to mention the grn wire in the a-pillar but looks like someone already has. Tnis is where I catch all my reverse inputs on these trucks (pre-nav model yrs). Good luck man.
Stik
charleston, S.C.
RE XM adapter
Vatahoelt, i have an 04 and installed pretty much the same things you are putting in or have already installed. i think only my headunit is different. i installed the kenwood 5120 and i used the following XM adapter and it works well..
http://www.myradiostore.com/antennas-cables/for-cables-miscellaneous/gm-single.html
hope this helps and sorry if its too late you do you any good...
happy holidays..
V
vatahoelt
NoVa
happy holidays..
thanks stik, that helps out a lot. unfortunately, 20+ inches of snow have put a damper on my install plans this weekend. so this will have to wait a little longer. i can't wait though.
jdpromo33
Proud Tahoe Owner
Bloomfield, New Jersey
LOL
You must be in NJ cuz I have the same snow issues.
I have an 04 and would like to do pretty much the same as you are doing.
I have a stock fac nav installed but it sucks. I also want to keep the stock drop down DVD player and not lose the steering wheel controls
Narco
Atlanta
is there not a way to just break the plastic off the xm antenna input so you dont have to buy an adapter?
V
vatahoelt
NoVa
LOL
actually i'm in Virginia. it basically snowed for the entire day last saturday. my back is dead from all the shoveling i did.
i've read other people say that they were able to do that. thursday i have the day off, so i'm going to attempt to install all this stuff. i'll let you know what i find.
