Need help with install. Please.
GMCYukonDriver
GMCYukonDriver
CA
I have another, probably stupid, question. Are the fittings for the fuel pressure regulator also -06AN? Yes, I got the one that came with the kit, and so I'm just wondering if the sizes are the same. I would need one male and female, but it's tough to tell sizing without having something here to test fit into it.
I will be ordering all this tomorrow once I figure this out. Ordering a 15ft roll of flex line. I figure it will take me about 30 minutes to hook it all up and get it running once these come in.
Atomic, I would love to get access to those pics. Is there any way you could compress them into a .zip file and e-mail them or put them on dropbox or something? Pictures help me out a lot more than detailed instructions, just easier for me. If it's too much hassle, don't worry about it. I've already started to gather my own photo/video collection of what I've found so far.
Thanks for all the help, guys. I never thought I'd be doing a mod this big this soon, but I couldn't pass it up when I saw it, so I don't have as much research behind it as I usually like to have.
AtomicHoe094
Atomichoe094
cleveland, OH
i might be able to just upload them to a photbucket album.. Which fitting are you talking about on the regulator?
bottom of regulator thread size. 1/4NPT to 6an (thats a 90* fitting)
which one?
GMCYukonDriver
GMCYukonDriver
CA
I'm pretty sure I need a 1/4 NPT to -06AN for the bottom fitting, 90 degree like you said. Then I need a 1/4 female NPT to -06AN for the fitting on the side, right?
GMCYukonDriver
GMCYukonDriver
CA
Ok, just ordered everything from Summit/Jegs (summit was backordered on one adapter).
I still don't know how to mount the air plenum to the throttle body, though. I don't see the hole you're talking about. Is there a way you could take a picture, or do you have one? I see there's one on the front of the injector pod, kind of between the barrels, but it looks like the hole on the plenum is more centered than that.
Thanks for all your help, it would've taken me quite a bit longer to figure out the fuel lines without that diagram and stuff. I should have it done this weekend, assuming everything goes together like it should.
foreverfalcon40
@ Atomic...you pulled your motor out or are you building a different one? Looks clean!
@Yukon...you got one heck of deal...take your time get it done right! Keep up the good work!
HAIGDEDNEDNA912
