New Derale 4L60E Transmission pan
Status
Not open for further replies.
Yes it replaces the stock pan with one that holds more fluid, and has a drain plug as well as cooling tubes. Here's what Derale states:
Features
  • Heavy gauge stamped steel construction
  • Two stage heat dissipating black finish
  • 1/8" NPT temperature sender port
  • Reduces fluid temperatures up to 50°F
  • Increases fluid capacity by 2 qts. 4 oz.
  • Patented turbulator cooling tubes add heat transfer capability
  • Magnetic drain plug with increased magnetic strength and rubber/steel washer
Status
GetGood
