No start issues again
rockola1971
Indiana (formerly IL)
Battery was at 13.2 when I went in last night not it's at 10.4
So something is drawing your battery down. Charge battery up to 13.0v+ and pull your BCM fuse and check it again the next morning. See if battery is still charged to atleast 12.8v+. You may also want to charge battery up fully and take it to an autozone or equivalent and have the battery load tested to make sure the battery isnt bad since a bad battery will mimic something draining it down....which it is indeed being drained down internally by a high resistance cell causing all the havoc in a bad battery. The battery has to be fully charged before it can be load tested properly.
There are alot of possible causes that have been known to happen to cause a battery to be drained down.
Bad battery, bad ignition switch (electrical one), bad alternator, bad grounds (BCM), wires partially shorted to ground, bad OEM amplifiers (at speakers), shorted auto hvac fan module, bad door switches (lights), bad starter (Solenoid partially shorted across contacts) and much more possibilities.
Follow the steps and well will narrow it down to the cause and then verify the bad part(s). I use to work on F/A-18C Hornets and F-14 Tomcats (as an electrician). I can handle your Yukon!
If or when we have to get in depth, you can PM me and Ill give you my phone number and we can real time troubleshoot this Yukon over the phone to get things moving faster. Get that battery fully charged and tested.
Phisher
Phisher
Winona Minnesota
I do have a friend down the street that has a code reader we're going to throw that on here later and hopefully it will tell me something but I'm hoping it's not the ignition switch again like I said I already put two grand into this lockout system to never have it happening and I was told but what I've read out there it can happen multiple times and at any time so I think all you again for all the help and rockola1971 i pmd you
MassHoe04
Western MA
So there's the issue with the fob 2 months ago when I had the original security lockout issue the shop that changed it when they gave me keys they didn't have a fob they said that my original one was busted anyways so I've never been able to lock the vehicle cuz I'm always afraid it's going to freaking lock me out for good and now that I've tried unsuccessfully numerous times doing the passlock reset I don't know what to do I don't know if I just take it to another shop and have them do the ignition switch out again I just and besides myself I mean I've spent so much money on this vehicle and it's not even worth it but you can't find anything nowadays either
We already determined that funds are extremely tight and you are in a pinch... But it has been to the shop once (at least) for the Passlock. Now, possibly mentioning another trip to the shop for fobs.
One of the Tech 2's built-in functions is programming fobs with the security system. If you could find the way to get one of these, you could program fobs all day long and not depend on a shop to do it for another couple hundred bucks.
When I had my no start this weekend, having the ability to look at the status of my ignition switch, live voltage readings and status of the park/neutral switch really helped me decide that the starter was my issue. And, it was. I was able to make that diagnosis as an educated guess, given all the information the Tech 2 was able to provide me.
Information is the key! The Tech 2 can provide so much information before you even disconnect any wires or put a wrench on anything.
I used to think: A real luxury. "Yeah. Tech 2... Good for you. Glad some of you got one. Nice, but expensive! Maybe someday, but I got other stuff to work on first."
I have used it twice and I have not had to bring it to a shop. I was able to diagnose myself and not have to rely on a shop to fix the issues.
Local shops charge about $100 a pop just for scan tool diagnostic fee. Add 1 hour minimums @ about $100/hr.... My Tech 2 is now officially paid for in the savings I realized. I am actually $100 ahead now!
All the things I thought were hype on having a Tech 2, are 100% legit. I didn't just drink the Tech 2 Kool-aid. My experience and what other people have found is true. Buy one, if you can find a way. Having this tool can make the world of difference.
Mechanics don't get stressed out when diagnosing problems. Because they have a Tech 2, or an Autel tablet scanner or Snap-On or something similar. The bi-directional scan tools dive into the systems so deep, you really can use the information to narrow down what parts are working and narrow things down to the part that is not doing what it should.
Sorry for the ramble, but just wanted to explain again, that the cost of a Tech 2 seems a bit much at first. But, it is a real game changer in being able to get the deep detailed information needed to figure things out.
If you can't buy a Tech 2 or make a friend with someone nearby, who has one... OK.
But, really... Our ability to help needs all the details you have. And be prepared for even more follow-up questions.
Diagnosing over forum posts is a lot like bringing your vehicle to an expert mechanic, but the mechanic is blind. You need to describe everything you see, hear, smell or know about the vehicle. Any detail, even if you think it is not important or related to the problem, could be helpful in diagnosing your problem. Something might pop up as an "ah-ha!" discovery and solution.
MassHoe04
Western MA
Very generous to offer a guy some 1-on-1 help @rockola1971
You represent the best of this forum and what it is all about!!
My security lights been blinking like crazy since 3 months ago when I was originally locked out with the ignition lockout they replaced all that and the security lights blinked ever since
if it is still blinking after they replaced it then how did you drive it home? presuming they did what they said they did it should not have even started up if the light is blinking, if you are driving around and the light is blinking then they did not replace it and simply bypassed it or did something wrong.
Yeah I wish that were the case I've looked around I've also called the auto shop that fixed my security lock out problem the last time and again that cost me two grand after only owning this vehicle for 2 weeks and they won't even speak with me about the truck they claim they have to look at it. . I can't afford to have it towed in look I'm a single dad with four kids.... I lost my wife due to covid I don't have money to buy a tech tool I don't have money half the time to put gas in it's kind of hard taking care of my family this is my family vehicle(more then a daily driver) I'd love to be able to go out and buy a $300 toy but I don't have that luxury I'm at the point I'm just putting this POS up for sale or taking it to the junkyard like I said I get crank no power to the pump unless I jump the relay security lights constantly blinking ...I just don't understand it I don't get why GM makes a product like this anyways a vehicle should lock out because this freaking sensor isn't working or because a relay is not working or because you're standing too close to your vehicle with your fob or you're doing whatever simple thing it takes to make these vehicles not work anymore I appreciate the help but again there's so many different things here I don't know which one I'm supposed to follow I hook the tool up on it this morning it won't even find anything it doesn't find the ECM it won't even give me a code so I don't understand what your tech tool is going to do anyways and as far as the multimeter it tells me so many different things I don't know what's going on other than the fact that I'll never buy a GM product again cuz they suck
and this if they worked on it and 2 weeks later it wont start and the security light is flashing then it should be on them, towing and all, they should have it towed in, not you.
maybe I am missing something here?
so from what I gather from a variety of post information is it will not start and security light may or may not be flashing?
so question?
by no start do you mean the starter turns but the engine will not run? (like it has no fuel, so it just spins?)
or is the starter not turning at all?
presuming it is spinning and you have confirmed it has fuel, then next up is spark
have you confirmed it has spark or no?
if it has spark and fuel then you really need some kind of tech tool to confirm it has correct air reading and timing.
check all fuses! every single one.
you mentioned the instrument cluster not showing things correctly? like low fuel, etc? this would lead me possibly to a bad ground, without going deep down that rabbit hole I would check the basic stuff around the battery and engine bay and body grounds under the front end and confirm the grounds are good
Phisher
Phisher
Winona Minnesota
All you guys represent the best of this forum I appreciate all that help you guys have been giving me here's another bonehead move of mine I didn't say that the stereo is not in this it's just the wires and they're all wrapped there was a aftermarket in here and the guy I bought it from took it out and was supposed to give it to me so I'm wondering if that's why it didn't die and have this issue two weeks after buying it and then the shop I took it to did the ignition and got me around the padlock but here we are a month later and it's happening again I'm starting to think this could be the culprit
radio has no say so over the security system, nor would it affect if the engine can start and run or not, at best it would be a crossed wire draining the battery while it is not running.
