Oil Pressure Low Stop Engine (replaced sensor)
David Smith
Savannah, GA
Also, does anyone know the specific torque specs for the oil pan bolts, pick up tube bolts and the flange bolt on the pick up tube?
kbuskill
NE. FL.
Going to grab a new pan gasket and the new o ring. I will be installing after I get off work today. Do I need to use loctite on any bolts?
No loctite but you will need some RTV for the corners of the pan.
Oil pan bolts
To engine and front cover 18 ft-lbs
To rear cover 106 in-lbs
To bellhousing, converter cover and transmission 37 ft-lbs
Transmission to oil pan bolts 37 ft-lbs
Not 100% sure on pickup tube torque specs as its not listed in my book.
Maybe @swathdiver Will chime in.
David Smith
Savannah, GA
Oil pan bolts
I need RTV in addition to the pan gasket? Should I just put a bead all the way around, or just in the corners?
kbuskill
NE. FL.
You only need a bead about an inch long where the timing cover and engine block meet the oil pan up front and the same in the rear where the rear main seal housing cover and block meet the oil pan.
David Smith
Savannah, GA
That makes sense. I will pick up a small tube today as well
David Smith
Savannah, GA
Does the RTV just go on the oil pan on top of the new gasket where the front cover and rear cover meet the block?
LanceD
Abq
Not sure if anyone has mentioned it but there are 2 different O ring sizes, make sure you use the correct one.
The pickup tube for the transmission is press fit, no nut/bolt. The bracket on the tube that secures it via a bell housing bolt is 37 ft lbs like the others.
Emshelton5
