Oil pressure on 07 Tahoe?
Administrator
per the gauge in my dash. I've had a manual gauge hooked up before and the two seems to jive pretty well so I find it pretty accurate :)
ezdaar
Chat Troll
Redneck central, Aka Houston
Not trying to scare ppl. just make you guys aware that 20psi is bad.
When I got this 06 5.3 silvy it was low just like everyones here.
I immediately changed to a cheap PF48 and castor oil 10-30 NON syntec.
Also dumped in a full can of seafoam and drove it for a week, nice and easy.
Then changed filter and drove it for 3 more days getting in it pretty good.
Finally drained it all out and the crap that came out was :Nonono:.
(Alil trick, while draining oil. once it gets to a trickle. Dump in 2 quarts of cheap castor oil as fast as you can and watch the plop plop come out of that pan, if it was as bad as mine.)
Installed a big PF63 and filled with Valvoline VR1 10-30 and BOOM! 40psi constant.
warmed it up and hit the freeway for some lovins. After aprox 15 mins of Freeway blasting 6K rpm speeds. My oil pressure idles at 40 and max's the gauge under Full WOT conditions.
Obviously there was major clogs in this engine that are now gone.
This is how it should be.
I have changed the oil few times since then and now run more expensive WIX filters. Oil pressure is constant and reliable. most importantly, no more sludge coming out
of my pan.
Sometimes it takes alil effort to make these engines do what they should.
I doubt the guy I bought the truck from ever changed the oil as the inside of the valve cover is doodoo brown and sticky as bubble yum gum in the sun.
I might get more aggressive with cleaning the interior of this 5.3 once I have a back up on my engine stand rdy to drop in.
Good oil pressure
This is very important if you guys hammer your engines like I do.
cold in driveway.
http://vid803.photobucket.com/album...2-0153-4A25-9556-734234C1C78A_zpsm2juuifd.mp4
Warm under cruise to work.
http://vid803.photobucket.com/album...4-05ED-4E67-B41D-E1E91502EDC2_zpsajune2ix.mp4
ezdaar
Chat Troll
Yes, PF63 is the OEM replacement for the tiny pos PF48. ALL LS engines use them.
Its even printed on the PF48 filters now.
I now use the WIX 57045, its the cross over for the PF63.
Here's list
O snap! that VR1 is even cheaper than auzoone sale right now..
Just placed my order. :)
Goodinblack
I Like Tacos
Dirty South
I now use the WIX 57045 its the cross over for the PF63.
Here's list
Did you really buy this Horse mask???
Administrator
:wtf: Lee
ezdaar
Chat Troll
Maybe, maybe not.
May or may not have worn it to a Toga party.
Not everything in those lists I bought. I do ALOT of window shopping.
Administrator
:lol:
Goodinblack
I Like Tacos
Dirty South
Lol
---------- Post added at 05:05 PM ---------- Previous post was at 05:04 PM ----------
Mods please change Dougs avtar
Thanks.
dougcolleen
