Ordered my 6.0
JKmotorsports
JKmotorsports
Austin, TX
UPDATE on the trans issue:
Pump isn't working. The torque converter must have slipped out just enough to come misaligned and then damaged the pump rotor while we were sliding the motor into place. That would explain the last 1/4" gap between the block and bellhousing that we were having a hard time with. So now I have to tear the trans apart and install a new pump rotor. I might as well upgrade to a 13 vane rotor since I have to replace it anyway. Hopefully someone locally will have the part so I can get my truck going by the end of the week.
Damn it:emotions122: I knew this entire swap was going way too easy...
AtomicHoe094
Atomichoe094
cleveland, OH
always something.. no matter if you double check or not.. something will pop up. done that to many times also.. grrr! and sorry man, i wanna see these videos!!
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Darn, that sucks! Time for the converter upgrade and tranny build? Which converter are you going with? It is going to make a WORLD of difference in performance!!!
DarkTahoe00
IN
Damn that really blows JK sorry to hear that! But that looks awesome,Hellva great job putting/making it! Its gonna be real nasty! Can't wait to see it going as I'm sure you are as well!
JKmotorsports
JKmotorsports
Austin, TX
Here's what the pump rotor is NOT suppossed to look like:
I replaced the pump rotor assembly. This is the way it should look when not damaged:
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Before or after the new power plant goes in?? :shocked:
As for the HP he is putting down now, a good estimate is ~600HP at the crank.
RNW72
