Ordered my 6.0
JKmotorsports
JKmotorsports
Austin, TX
What's the latest bro?
B
JK update/video please :)
Still working on it. I'm going to try to have the injectors balance tested and see if there are any out of spec. Everything else looks okay so far. All the injectors and coils are firing, no vacuum leaks, O2 sensors new, compression ok, etc.
Young28
The Yukon God
ga
Jk what your doing is sick.
I have a question though.
This may have been discussed before but what is a must to do motor wise when your looking at getting a supercharger?
Back on topic
axekick
Austin, TX
I see there are a lot of people on this forum from ATX. Do you guys ever get together like a TahoeYukon club or anything? I'd like to see some of these projects that are going on. I have tools.
Max
Mile High
Denver
Back on topic
On your LQ4 you don't have to do anything. These motors will take a good amount of boost before you have to worry, just make sure the tune is solid and it's getting plenty of fuel. 500hp with stock internals is quite feasible with a 6.0 but adding some arp rod bolts, head studs, and a mild cam/springs/retainers/pushrods will help longevity.
Young28
The Yukon God
ga
i shoulda just pmed you. I knew you would have a good answer for me. Thanks bro.:Handshake:
JKmotorsports
JKmotorsports
Austin, TX
^^^Exactly what Max said. The tune is going to be the most important factor in dialing everything in right so the timing and fuel trims are spot on to avoid detonation and leaning out the afr while under boost.
JKmotorsports
JKmotorsports
Austin, TX
We need to. There's a few different car meets every Sat night; the better ones are the one at the Home Depot on 1431 between RR and Cedar Park, one at the Y in Oak HIll, and another in the Gateway shopping cntr at 360 & 183.
I'm down for a get together soon. If I remember, I'll start a thread in the lounge section later tonight to see who all wants to meet up one weekend.
axekick
Austin, TX
Do it. I live right down the street from the 1431 Home Depot. I didn't know the car show was there now. It must be the same guys that used to go by the antique mall until Outback Steakhouse moved in. So are you driving your truck now or what?
tdeaton3
