Question for you E-fan guys
Mr45
Florida
SO I'm thinking about going the E-fan route with my Tahoe, and I saw a few different options, and as far as I can tell you can either get a kit, complete with shroud/mounting surface etc.
The other option as posted by JK (IIRC) is where two fans just get stuck to the radiator. Will this setup work as efficient as a setup with a shroud?
This setup, with a shroud: (Jennabear)
Vs.
without a shroud (JK Motorsports)
It appears that a simple setup with 2 fans, like JK can be put together for minimal $$, compared to a setup complete with Shroud.
Just wondering what the differences in effectiveness are.
JKmotorsports
Austin, TX
Set-ups with a shroud are more efficient at pulling air through the entire radiator surfaces rather than just where the fans are mounted. My set-up works great, but can be made to work better with a shroud. I had planned on making my own shroud with ABS/fiberglass, but just got lazy, lol. I like doing things from scratch rather than buying kits because for me it's easy and definitely a lot cheaper.
Either way, with or w/o a shroud, a dual e-fan setup is much better than the stock engine driven fan.
Mr45
Mr45
Florida
Thanks for your input.
So without a shroud, you have no cooling issues? Long idling etc?
JKmotorsports
Austin, TX
No issues whatsoever. A/C cools much quicker during startup and stays colder while idling and sitting in slow traffic and eng temps stay a bit cooler as well during idling. We've had 100+ degrees day here for the past few weeks and the a/c and eng have no problems staying cool even in midday traffic. You might also want to swap to a lower t-stat also, maybe a 180* if your eng is mostly stock. This will help keep the eng running a little cooler also. Whereabouts in Fl are you? If you're farther south, you might even want to try a 160* t-stat.
Mr45
Mr45
Florida
Engine is mostly stock. I'm about an hour south of Tampa. 180* should suffice, I think.
TheFuzz
Idiot Police
Spurbury, VT
So Jenna and JK, what are your opinions about the kits that Ty found on e-bay? The sellers seem kinda like *********, but they have mostly positive feedback and the kits look pretty well put together. I'm not all that good with this kind of stuff yet, but I have a feeling I'll be keeping the Yukon for a long time...might as well start with a kit. Any thoughts?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
I am not a fan of the radiator mod, I wouldn't want to have to drill into anything. I like that my fans are set up for different speeds (via the PCM) and will turn on and off as needed, thus saving more energy/power.
I am sure those fans will work just fine, I am more inclined to the plug and play applications.
BOSS
The People's A D M I N
Dallas
I just did this efan install on my ************* daily driver yesterday (in the 100deg. heat), not too bad ...the pain in the ass was getting to the radiator backside because of the heat exchanger for the AC.
B
HamptonGarage
