Question on DRL module and foglights
wtbtahoe
Someone that might contact Tbruz or answer the question regarding the parts list for the foglight wiring.
T
Tbruz
Windham NH
Didn't see this post until Sunlit PM'd me
There are 7 parts required to add STOCK foglights to any of our OBS rigs.
1) Bumper: GM pn 15680830 is chrome smooth(no bumper guard or strip holes) LMC sells other options but the holes are not aligned and my LMC bumper shows signs of rust after less than 12 months on my truck
2)Fog Lamps: 2 required p/n 12477563; available aftermarket or Ebay
3)Fog Light buckets(NLA);
left is p/n 15045495
right is p/n 15045494
4) Fog light switch for vertical position p/n 15738877 (NLA) found occasionally on Ebay. If you go into the horizontal position; usually used by the push button 4wd system, the fog light switch is 15687022, again Ebay is your best shot for this.
5) Switch bezel plate vertical mounting, PN varies based on 1 hole 15694888(barn doors w/fog lights) or 3 hole 15696254( tail gate, wiper and fog light). If you go into the horizontal position, 1 hole Bezel is 15696260
6) Interior harness (NLA from GM) p/n 15743770 was available from Vintage parts
7) exterior harness(NLA from GM) p/n 15045442 was available from Vintage Parts
An option to the two GM harnesses is a single harness option from EBAY; Search on your year tahoe fog light harness. I haven't used that so I cannot vouch for it, but it looks like it could/might work. Item number 160492876415 is currently on Ebay and looks like you send your switch to them and they wire it up and send back a working harness/switch combo.
Let me know if you need further help.
Tbruz
wtbtahoe
Thanks Tbruz. I will start collecting the parts and if I run into any problems, I will definitely hit you up. As you can see from one of my earlier posts, I have the bumper and lights but the previous owner did not finish hooking them up.
And thanks to Sunlit Comet for the assistance.
T
Tbruz
Windham NH
If anyone is interested, OEM Stock Fog Light buckets (left and right) for the OBS in-bumper fog lights are currently available on EBAY; seller has 67 sets!!!
These are NLA parts from GM and were extremely difficult to locate.
Tbruz
ihadtheories
