Questions about 4x4 4 hi & 4 lo
D
driven_mad
@driven_mad Congratulations man, mine is also an 08. They are great rigs, educate yourself on the AFM thing just in case.
My Tahoe also has 20 inch wheels but after I put 33 inch tires on them they don't look too bad.
Did you install a lift on your Tahoe? I like how the bottom of the fenders are above the center height of the wheels.
I am considering leveling springs for the front and potentially some z71 springs/spacer for the rear.
Dustin Jackson
@driven_mad Yes I have a bit of a lift on it, details can be found in my signature below my post.
This picture is before I put the 2.5 inch spacers on. It is using Moog 81244 springs in the front and Moog 81069 springs in the rear with bilstein 5100 shocks set at factory setting.
D
driven_mad
Are these springs larger then the z71 springs that your Tahoe had and or have a greater load rating?
How much lift did you achieve and did you need any additional parts before the spacers?
Dustin Jackson
@driven_mad When I got my Tahoe it had lowering springs in the back so I had no frame of reference. Can't answer your first question.
I'd say I got about an 1.5 inch of lift in the back and maybe 1 inch in the front, the rest of my suspension was stock. Keep in mind I was on lowering springs so you will get less lift in the back.
Here is how my tahoe looked when I got it with lowering springs in the back and stock front:
Here is with Moog springs and bilstein shocks:
bobarich
