randeez
Is there not much force on those straps or am I overthinking it? With their intended purpose, it just seems like a LOT of leverage against something acting in single shear.
It's still sprung by the coil over, I'm not compressing the suspension with it just removing all extension.
If I were like jumping this thing where the coilover went from full compression to full extension with the inertia behind it I would make a real lower mount.
For my purpose the only thing I'm doing is hanging the a-arms/wheel and the spring tension on it for a few seconds.
Top I'm not worried about, the hardware I'm getting (tho no shear values) is rated 170,000psi of tensile strength.
The bottom is all grade 8 , 1/2" bolts, the rod coupler is also grade 8, made from 3/4" hex stock. If it bends/breaks I'll try with grade 9 hardware- over a hundred bux in just hardware for the lower mounts I figured I'd see how the 8 does first.
Lmk what you're thinking dub...I mostly just wing this shit
