Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
pwtr02ss
Tennessee
I'm not a pro in the ac department but I don't see what would be special about them, other than flow/volume like you said. I thought they were just filled with the silica beads to dry the air, hence the reason you never leave them open if you have it off the vehicle. I put a used one on a camaro a long time ago. It froze and blew Freon/oil all over the engine bay.
as for the orifice tube, just looks partially clogged and needs replaced? Here's a new one I bought for the avalanche but haven't installed
randeez
randeez
south florida
wellllll i threw in the injectors i just got cleaned.... want to just get it moving, i think its going to be a few weeks before i spend more (big) money. atleast i know the tune ive already got should be pretty close, if i changed all this crap and injectors i'll prob be chasing problems
i'll keep pecking away at the little stuff.
got most of the wiring harness back in, gapped some plugs down and threw them in, need to see how the coils work with these headers, if i can use stock mounts or if i need to mount them remotely
randeez
randeez
south florida
drained trans, waiting on dexvi and filter to get here this week to drop pan.
changed the oil/filter..was a few drops a water in it from pulling heads - i always fear theres a ton of water in the pan every time i pull the heads but never is lol
draped most of the wiring harness back out and connected it.
ordered some fittings to hack fuel system back together - i already have extra check valves so im going to prob replace those, interested to see if theyre blown out
started removing the fuel purge solenoid - it was full of oil but i think the line runs back to the fuel hat? prob just going to cut and cap it.
still need to see what i got to do with coils, may work on that tonight
constantly seems like im so far away lol.
randeez
randeez
south florida
pulled the funky fuel line y set up i had... i really only needed to swap 1 fitting to put the 12an feed hose on it but i wanted to see if the check valves still worked, which they did. i had an extra 6an (stock line) one that i threw i just because it was apart. put it all back together and connected the new 12an feed to it. used an adapter to connect the new 12an return to the 8an i had. its all back together - essentially the same as it was and ready to run.
cut and capped the fuel purge solenoid.
kind of dreading pulling the trans pan and seeing whats in there. have a feeling im not going to feel good about just changing the fluid and filter and running it again
pwtr02ss
Tennessee
trans been acting weird?
Dflo92
