Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
well... i put the neighborhood on notice
fire this ****** up about an hour ago
nothing but forward facing headers, no water, open throttle body, no o2s.
i doubt it turned over 5 times before it fired right up, watch the oil pressure come up and then remembered there was no tranny fluid in it and shut it off lol
mostly just wanted to check for leaks (oil/gas), check i made up the coils right - cause swapped some of the "input" side of the coil plugs cause the plug wires i had around barely worked and didnt feel like making up new ones....and then doubted myself on which way they went. and to see how the valve lash went, ie: if the pushrods were too short/long. couldnt really hear over the open headers but it ran smooth considering the circumstances
Sam Harris
Texas
Haha...! Awesome. Can’t wait.....!.
'Bout time ;):D
randeez
randeez
south florida
Little bit of overreaction on the trans...was pretty clean lol
The small bits that came out were like pinky nail sized if that makes sense. I assumed there were larger peices that couldn't make it out the drain hole. even the magnet isnt as bad as i thought, those little black crusties are about the extent of it...all i did was let the fluid drain before those pics. cleaned it all up, new filter, verified the dip stick full mark was at the pan rail and put 12 qts back in it
Swapped fitting into the 40k...they've always weeped a little, apparently the fittings I had bottom out before the flare engages tight enough. The flare should engage on these fittings but I put some thread sealer on it anyway
And the other drier/accumulator came
After starting it up, it's incredibly loud, I threw on the one wastegate I had, the pre o2 sensors and the post wideband...still loud af. So I ordered the other wastegate, couldn't find local but Amazon 1 day shipping gonna have to do
20210605_122727.jpg 20210605_122733.jpg 20210605_122734.jpg 20210602_181306.jpg 20210603_181255.jpg
Sam Harris
Texas
View attachment 281114 View attachment 281115 View attachment 281116 View attachment 281117 View attachment 281118
Damn.. I need to hear this ....!
Cashbagz1
