Rear wiper motor cover clips.....
Stresst
I tried to remove my rear wiper arm on my 00 Escalade, anyway inside covering the rear wiper motor there is a cover which HAD 4 plastic "clips". I broke all 4 getting them out. Does anyone know what the part number is for them? Or what I else I can do?
Lastly I couldnt get the wiper arm off, any suggestion? I know I know a total mess! :emotions122:
drowndindreams
Unknown
yea i remember i broke them too. i dont have a part number but you can easily find them at an autoparts place like pepboys autozone etc.
taylorjm
Saginaw, MI
So you took off the interior panels on the hatch to expose the motor, and there was a second cover on the motor that you broke the clips off? I have to take mine off and I know there's a bolt on the outside of the truck, at the base of the wiper arm and under the wiper arm. You have to pull the arm back like you were changing the blade to see the bolt hiding in there. I think my motor only had two bolts holding it on, I don't remember seeing any cover with clips.
---------- Post added at 04:17 PM ---------- Previous post was at 04:15 PM ----------
Did your a/c guy tell you that it's the rear wiper motor causing your problem now? lol
S
Stresst
There is a cover over the wiper motor which HAD 4 plastic clips that snapped like toothpicks! I cannot believe there is a bolt...have to check later when I get out of here.
As far as the a/c guy goes yes he said the vent temps would drop by 7 degrees due to better airflow over the rear window! :)
drowndindreams
Unknown
he's talking about the entire assembly. if im not mistaken i think youre only talking about the cover to the assembly
S
Stresst
No, all im trying to do is replace the wiper arm. I first I broke the 4 push in style clips holding the cover which I needed to remove to disconnect the washer fluid line. I also could not remove the rear wiper arm. But I cannot get it off the shaft.
S
Stresst
Anyone have a suggestion on how I can remove the rear wiper arm?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Rear REMOVAL PROCEDURE
79292846
  1. Disconnect the washer hose.
79292835
  1. Lift the wiper arm from the windshield.
  2. Disengage the retaining latch with a screwdriver.
79292847
  1. Disengage the washer hose and grommet from the liftglass.
  2. Remove the wiper arm from the wiper motor drive shaft.
INSTALLATION PROCEDURE
79292847
  1. Install the wiper arm assembly onto the wiper motor driveshaft with the wiper blade in parked position (blade parallel to the edge to the glass).
  2. Install the washer hose and grommet in the liftglass.
79292837
  1. Lift the wiper arm extension and push in the retaining latch when the head is fully seated onto the driveshaft.
79292846
  1. Connect the washer hose.
S
Stresst
Yeah thats what I thought/did but it will not come off the motor shaft......
Dalewg
