S
stretchit
Another update....... all previously crimped wires have been individually soldered. Even moved a back ground thinking it might help lol.
LITTERALLY NOTHING HAS CHANGED. guess it's time to take engine out and replace harness? Who knows at this point. Might look for a donor car to put engine in. F U, GM. Garbage electrical issues. Stupid. Im mad
something doesn't make sense, you tested each wire for ohm's/ground/voltage?
tested each pin between the pcm and throttle body?
S
stretchit
No just visual inspections. Did some research and am now going to check each wire Individually, ohms, voltage, and whatever else. Thanks for the help, I will keep posting updates. Hopefully I can pin point it!
S
stretchit
The cable from the pedal sensor to the TAC module has a continuous electrical path. Same for the cable from the TAC module (right side) all the way to the TPS connection. Going to check the other 8 wires coming from that TAC module cable to the fuse box.
S
stretchit
Just finished checking and I have flow all the way thru to the fuse block. Noticed a little dirt in the fuse box right where the cables connect. Just going to clean it real good and put everything back. If that doesn't change anything I will move on to checking grounds for continuous flow. After that I'll plug the battery back in and check voltage. Then idk lol
S
stretchit
Also this is what my OBD port looks like. Thought this truck had a CAN network but im not sure. That's the first thing I wanted to test. Based off the port, I can't test it thru there.
S
stretchit
follow the harness for the obd port back and see what's up there should be more than 3 wires
It has four wires that I followed and they just tie into the harness then connect I to the driver side fuse box. I guess I should test continuity? Or keep digging. Seems like it should have more then 4 pins/wires in the OBD port
*Red arrow is the 4 wires from the OBD port
*Green arrow is the OBD port
*forgot to mention that the previous owner had a tracker that was spliced Into the ground and voltage wire of the OBD. Took that out but the throttle response issue didn't change
you seem to be missing pins 6 & 14 which is can bus high & low, has this thing had a engine swap or anything?
S
stretchit
No not too my knowledge. Its a 5.3 LM7. When I took it apart it looked pretty dirty and stock.
Thanks for letting me know, I felt like I should have those to test it. Not sure what to do now lol thanks again for the help
Smityinms
