Remove roof-rack.....COMPLETELY?
StormTrooper2181
if you have any old GM interior plastic door panel tabs they work well with silicone.
KMeloney
KMeloney-you wouldn't happen to have pictures of your roof AFTER you removed the stock rack? And pics of the holes filled and/or plugged? Thanks for any support.
Yep, I do...
It's tough to see on black, but you'll notice the door molding I used along the length of the roof to cover the holes.
FYI, it was a PITA to do. I dremeled out a space on the underside of the molding where the nutserts sit. That was the PITA part. Otherwise, it was just a matter of affixing the molding to the roof.
mjenk430
Unionville, VA
Yep, I do...
Where did you buy the molding? I wonder if it comes in white?
mjenk430
Unionville, VA
You purchased the moldings that are beveled on both ends, right? How did you cut it to the length you wanted? Just cut a chunk out of the middle and have a seam? Is it visible? Or did you just cut one of the beveled ends off?
KMeloney
I did the former. But, even if you cut the end off (of one end) and did it that way, you couldn't see the seam, especially with black.
kamarsh94
