Remove roof-rack.....COMPLETELY?
eanmizell
Tomball(Houston), TX
my hybrid didnt come with the roofrack, look at my sig pic and you can see, matter of fact here is one since I tinted my tails and put on the black emblems
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Sumo....what'd you use to plug up the holes?
well it was temporary. I have esky racks on it now. But what i do have are plastic inserts that fit in the hole nicely. WHen i Prep a new car at work, some of them come with those plastic inserts. They are there so debris dont get stuck in there and cause the threads to strip.
ELIM
SoCAL
Where can I find those plastic inserts? Also, what size?
sumo
rhode island
Ill take a pic of one, If i have some in my tool box other than what i have for myself ill send them over. You should also be able to find them at any hardware store.
ELIM
SoCAL
....You can't leave the holes unplugged or you'll get water in the headliner....
I would think that the headliner has some protection from an accidental loose bolt, etc?
Sounds good. Silicone was added to the holes in mine but maybe I'll add a second layer of protection if the above is true.
KMeloney
I'm going to say no. The bolts sandwich the rack's plastic parts to the roof, and the whole design of the way the rack mounts IS the protection against water getting in, I'd say. So, when you expose the nutserts, don't have plastic wedged against the openings, etc., then you at least invite water to get in. I'm not saying water WILL get in the headliner, but I've read about it here and on the TahoeForum. Better safe than sorry!
InTruckDesign
SW CT,
No rack here...used a nice door molding that has a similar profile as the ribs on the roof.
[/IMG]
Administrator
DSCN4936.jpg[/IMG]
Do you have pics of the top of the roof so we can see it? :)
My01yuk
Dallas Tx
I went to Ace Hardware yesterday and bought 10 little plastic inserts and put them in. They are not flushed but close enough and should help prevent any water getting in. I removed my rack to do the mod gdddup did(bootleg esky rack) but liked the way it looked without the rack. I'm about 30% done with it so the other 70% will be done here and there until it's ready to be put back on.
ezmoney1981
