petethepug
Michael
Do it all at once. If you can fool the MagRide into working harder for the drop, all the better.
You need a bi-directional scanner, such as a Tech 2, and you perform the ALC procedure with the scanner.Okay thanks! How do you reset it?
Sweet I have a bi directional scan tool I should be good to go then!You need a bi-directional scanner, such as a Tech 2, and you perform the ALC procedure with the scanner.
