rocketman76
The install was simple enough. I did not forget to swap out bump stops, new shorter pale yellow parts packaged in same box as springs. My understanding was that the free travel was reserved for the 4" inch drop option, no 1" spacer between lower spring insulator and spring perch.
I don't bottom out while towing or carrying a load, it happens without a load, but more frequent with my family: wife, (138 lbs ridding shotgun), my 5 year old,(43 lbs riding behind me) my 7 year old, (60 lbs sitting behind wife), my 1 year old, (22 lbs sitting between 5 and 7 yo), and my 10 year old,( 74 lbs sitting in the rear seat.
If the solution is a free travel mod, not happening.
Why buy a kit with so many problems and permanent mods.
I have installed complete Maximum Motorsports, Griggs Racing and Steeda suspension kits on my personal street and track cars, all requiring some fine tuning via spring rates, coil overs adjustments, double adjustable shocks and struts, adjustable upper and lower A arms in some, adjustable upper and lower rear control arms, caster camber plates, Watts Links on some, torque or pan hard bars on others. This has been the worst fitting kit in 20 years of building cars, (Newbie to Forum not cars).
THANK YOU ALL FOR YOU IMPUT. I"M OUT!
