rocketman76
I will measure the space between the axle and bump stop and recheck spring PN.
I placed the lower spring insulator on top of the spacer before setting them on the axle spring perch, then the spring with the upper spring insulator. I followed the instructions below.
g) Carefully remove the OEM coil springs from their mounting locations (Photo 5). Retain the upper and lower spring insulators for later reuse.
h) Position the Belltech lowering coil springs in place of the OEM components (Photo 6). Be sure to install and locate the upper and lower insulators as removed above. If you are using the one inch spacer to reduce the amount of lowering, install them at this time to the bottom of the spring, on the axle spring mounting point.
