Right/rear window, rolled up & now unresponsive
Hello. I did not get too far yesterday, family/kid stuff. I did roll around under the right/rear side looking for a ground cable/wire. Couldn't fine one. I will look closer today. Wes, thanks for the clarification of the word "dirty" in an electrical schematic, I did not know that.
Free Tip Saturday: if you want to "tag" someone, either quote that person's post (like I did here), or use the "@" symbol and start typing the user's name. Then pick the correct one from the picklist of users. Finish typing your message.
If you don't do either one of those, your target won't be a sure hit.
Thank you. Test here.
mikez71
So there is power!? Jammed or worn out motor?
OK. So today, my other kid did not hear a sound next to window motor (w/panel off).
I don’t know if I am doing this right, but I got no light, w/ignition on, trying this pin and the one next to it.
Any other tests I should do before door panel goes back?
I also tested the power on & the RR door switch.
thank you
What year are we working on, or did I miss that? Some of these within the same body style have somewhat different electrical systems.
Have the appropriate fuse(s) been verified as having power going through it?
OK, I need to add a signature. It is a:
2011 Chevy Suburban, 2500, 4x4, LT.
I forgot, in my initial post, I said I had a lil' electrical b lackout when I went out to start it the other day. I did check the battery cables (look brand new) and the ground was a tad loose. I tightened it. I as assuming the window is a different thing.
Thank you.
I found a couple videos on this. ! read (Reliable sources? - Don't know.)
circuit board needs checking for crud?
This one says there is a circuit breaker on kick panel w/a fuse for passenger side windows. Can't be that one though, I think, because FR window works fine. About 1/2 way down, specifies 2008-2014 sub.
89Suburban
Bull in the china shop
SE PA
thank you
It wouldn't light up moving the switch back and forth?
