Lol. Well one of us could have anyway.we couldve 4l80 swapped this thing and broken the input shaft by now![]()
Only problem I was just thinking with my blower, cam, and bigger injectors I might hurt my engine. It wants me to rev it up to 4K rpms and stuff. I’m not comfortable doing that with a stock tune on my motor. Idk. @randeez do you have any insight?Maybe with the stock tune. I have done the case relearn on our envoy and it worked fine.
So yeah, even on completely stock vehicles they sound like you’re trying to blow em up. First few I did I had trouble because I wasn’t holding them long enough. With any exhaust mods, it’s going to be ridiculous.blow that **** up
kidding - let me read back the last couple pages and see wtf youre doing
was coolant temp above like 135 or something like that? theres a temp threshold that needs to be met iircOk, got the passlock to work. Now my tach isn’t working and it set a code for crankshaft position variation relearn. I tried the relearn procedure with the Tech2 but it says to accelerate to the fuel cutoff rpm which fir a V8 it says is 4K. But the fuel cutoff never happens, I went up to the rev limiter a couple times. My neighbors who were out in front of their crappy little skinny houses with no backyards went inside after that. This thing is loud af lol. Woke up the whole neighborhood but that’s ok, they’re annoying over there anyway all the time.
If anybody has done this, please chime in. I’ll try again tomorrow. At least it’s running now.
I wonder if I need to install the stock tune and then try this.
Idk lol. Without a tach I was lost. I wasn’t setting the parking brake either which it says to do. Mine doesn’t work so I didn’t bother but it could look for that. But hey I disconnected the battery for awhile, then reconnected it and my tach is working now. Also I realized there was another abnormality when I was trying the procedure- the temp gauge was reading 180* but the program said it was waiting for minimum temp to be reached which happened in a few minutes and then it started with the next step, revving it up to 4K. I realized now the engine couldn’t have been warm, it hadn’t been started all day. Now it reads about 120* and the tach is working so maybe something needed to be reset. I’ll try the procedure tomorrow, it’s quiet time in the hood and peeps are outside enjoying the nice weather. This truck with pretty much open headers is gonna be hell on them for a few minutes. I did drive around the block and it runs great. I won’t know if this fixed the trans until I do some longer drives which I’m hesitant about doing until I get this latest issue resolved.So yeah, even on completely stock vehicles they sound like you’re trying to blow em up. First few I did I had trouble because I wasn’t holding them long enough. With any exhaust mods, it’s going to be ridiculous.
Anyways…. Do you think you are holding wide open until 4K? Or do you think you’re starting to lift because you’re thinking it’ll hit 7k by the time you’re foot is actually off the throttle completely
