Sam Harris
Great work as usual Mark!Put the lid back in; can’t even see the repair and it works great. Probably way stronger than the original.
As usual.Great work as usual Mark!
Sounds great Mark!Thanks guys. I got the shorties installed today and I’m running with no muffler ATM. I ordered a SLP Loud Mouth bullet muffler, it’s about all I have room for. I wanted to get an Aero Turbine but at 6” tall there was no way, a 4” tall muffler is all I can fit. Then I’ll see what i can do for a turn down. I have almost no room left over as far as length. Right now it’s terrible in the cab so I’ll see what the SLP does, plus I need to get the exit farther back. It’s under the rear seats now. Anyway they look good in the engine bay. I did have to modify the firewall on the passenger side and the heat shield on the driver side, and I took my 5lb mini sledge to the floorboard right where it angled up, where the cat was hitting and vibrating so that’s fixed. That drove me crazy, every time I hit the gas hard it vibrated and rattled bad. Got a new sticker for my toolbox. Oh, and Justin is working on my tune to help with more chop by pulling timing at idle and lowering the idle. It’s still idling at 800 for some reason.
View attachment 250995 View attachment 250996
Yeah I don’t like this exhaust. I am extremely limited though, there’s literally zero room. I might have that shop give a shot at building something but I’ll have to leave cats in if I do. They will just be really small cats. Right now it sounds like he’ll inside the cab, probably because it exits straight out the back with no dump, and that point is under the rear seat. I need another 24” of length to get it near the back of the cab where it was. The muffler will get it close, then I’ll see about a dump. I can’t find any real short 3” ones and I need it to be about 6” long I think.I didn't know you went back with a stock cam.![]()
Yeah it’s bad right now aired out. I went grocery shopping today. I got to the store and did what I always do- laid it out. The comps were still running filling the tank and I always let it fill to 200 psi so when I come out I hit the remote start and it brings itself to ride height and then refills the tank again while I load groceries and get rid of the cart. But it sounded so bad inside laid out that I hit the ride height button and then it took even longer to pump up because I just used a bunch of air. I’ll let it fill the tank first and THEN air it out from now on. I really need to get it to exit through that space between the cab and bed.Yeah, at least getting it past the back of the cab will make a big difference. You have a wall there separating it from the passenger compartment unlike in an SUV, so it's almost like having it exit out the back of the SUV. Well, other than it resonating under the bed.
