Dantheman1540
I personally love the beside exit but not on a bagged beauty. Those are better for ratty muscle cars/trucks.
Hope you come up with something cool.
Even if I was ok with that, there’s no route for it due to my 4-links being right there as well as the crossmember that’s right behind the cab. I’ll see if I can find a pic. I would need dual exits anyway, I couldn’t do a single exit. That would drive me crazy to not have one on the other side. I thought about all this long ago as well as a way to get it out the rear, maybe through the bumper. I just have limited room due to the frame height, rear suspension components, air lines etc. You have to remember the links travel a long ways up and down- I barely had room between the limits of them to run a single hard air line through on either side at a point fairly close to their pivot point in the front. There’s no way an exhaust pipe would work.Pretty sure I already know the answer, but how do you feel about the exhaust exiting through the panel? I mean having professional body work done. Not those cheap trim pieces that you cut a hole, screw 'em down and route the pipe through that. I'm thinking more of an arch(es) formed into the very bottom in the area in front of the right rear wheel. Have the tip(s) come out there. It'd technically be under the panel rather than through it.
NOT this:
Something like this, but way cleaner. Have the notch(es) match the tip(s):
Got the Borla today and was able to temp it in place with the 3” downturn using clamps. It sounds pretty good so I’m gonna take it to a muffler shop and have them weld them in place and weld the hanger to it so it doesn’t bounce. The Borla is stainless and the rest is steel so I think it needs to be MIG welded?
I hope they didn't beat you out of your money!Also, I haven’t heard a peep out of BT Diesel Works since I paid them $195 two weeks ago. I called and left a message. I emailed them. Nothing.
I’m sure they’re like BlackBear, super busy. It’s just annoying. I think it’s just a couple people and they’re the only ones providing this service.I hope they didn't beat you out of your money!
