Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
I’m gonna have the shop see about doing something from the cats back. I know a change in the muffler will help. IDK, kind of out of options. I know I’m not gonna get the sound I want but it will change, believe me. Might just put an Aero Turbine muffler on it or none at all. Shorties will make a bit of a difference, not as much as long tubes I realize that. As far as cats, I know the super small ones advertised as high-flow which are the ones I’m looking at, which are used on Kooks or ARH y-pipes, might help. They will definitely take up less room than the huge stock ones so I won’t have the thing hitting the floorboard when I hit the throttle. I’ll do what I can and see what it sounds like. I’m just trying to not get bummed out.
magnaflow cat's are smaller than stock at least the ones the shop put on my 12 are
That they are, in both length and girth. Maybe the shorter length earns their "high flow" designation? I don't know. I got an offer for around $260 to recycle my OEM cats, so that's what I'm gonna do with them.
Do you have to have cats for emissions or___? I was under the impression you wanted it more on the rowdy side. Cats make great mufflers. lol
No, I don’t need them. The downstream sensors are tuned out and it’s registered in a county with no emissions testing. But no muffler shop will work on it without cats or at least they will only work on it back from where the cats are supposed to be. I pretty much need a new system from the shorties back. Nothing is stock, it’s been built to fit the truck. I can’t even remove the system without cutting the muffler off- it’s one long contraption all welded together. You can see it in the video I posted earlier. I’m not even sure how they built it. I pulled it loose at the manifolds and dropped the front down but the muffler won’t let it come forward and out from between the rear crossmember and bed. They must have welded the muffler on with it like this, then lifted the front up and mounted it to the manifolds. There’s no way to weld the top around the muffler without dropping the front so you can spin it to get to the top. I might be able to weld pipe where the cats are if I leave the rest alone and just put a muffler on with clamps if I don’t take it to a shop. This isn’t like a truck where I can buy a system that fits and install it myself, it has to be custom bent.
I'm trackin. Yeah, you're kinda in a bind unless you do it yourself. I get what you're saying about it all being welded in place. I welded my muffler in place because it was much faster to do it that way than to make it "removable". It wasn't convenient by any means. I couldn't fit my head up there to weld the top with my hood on. So I aimed, squinted tight, pulled the trigger, moved by feel, checked my work and repeated until the top was fully welded.
My eyelids were burnt!
If you could come up with a way to section it, band clamps are a convenient and solid option.
The EBay idiots I bought the console lid from never shipped it, just provided a tracking # so I got a refund and ordered one off Amazon. But I’m thinking that latch will probably break too and I want a strong one so I drilled a hole through the thing with a 1/16” drill bit, cut the bit to length, and used it as a metal rod to strengthen it and then bought another tube of Fusor 142 Plastic Repair Adhesive ( I wanted some on hand anyway) to use as a repair. I think my design is strong. It turned out a bit messy because it’s about 95 in my garage and the Fusor has a 5 minute working time in normal conditions, today I think I had about 2-3.
4CEEB8A4-5819-4655-BCFF-00BC3FB78724.jpeg 60F6E5C5-9659-4F56-A01C-B90A1CDCB636.jpeg CBB3DB8B-5983-4BDB-A414-4E8597B7028B.jpeg E8B98DC7-915C-4912-806D-18A8313293AB.jpeg
