Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
Ehh. So much for waiting. Riveting done. Cerakote done on the plastic, ready for install tomorrow. I bought new LED license plate lights to go along with everything.
Money shot. Now I need to remove the cowl and hood trim and remove the white specks of wax that spun off the buffer and landed there months ago. I have tried everything and the only thing that takes them off is scotchbright. I want to Cerakote them so hopefully they’re protected. The plastic on the rear bumper had the same specs and it looks awesome now after I used that process. The stupid specks sorta bonded themselves to the plastic.9B20F25F-00C1-4E8C-B802-1F327033F60B.jpeg385D3518-5871-4DED-BF09-ED59DFD517FB.jpegFFB7B0DB-C59F-4106-B2B1-2E8D36C66EF5.jpeg
Money shot. Now I need to remove the cowl and hood trim and remove the white specks of wax that spun off the buffer and landed there months ago. I have tried everything and the only thing that takes them off is scotchbright. I want to Cerakote them so hopefully they’re protected. The plastic on the rear bumper had the same specs and it looks awesome now after I used that process. The stupid specks sorta bonded themselves to the plastic.View attachment 347244View attachment 347245View attachment 347246
Have you tried a stiff brush? The type that you'd buy in HF in a package of 3--comes with nylon, brass and steel. The nylon brush might be stiff enough to get it off.
I don’t think it would work, I have to scrub quite a bit with the scotchbrite in order to get it off. Alcohol doesn’t touch it but I just tried mineral spirits and it removes some so it cuts down on the scotchbrite time. The stuff is stubborn. Weird thing is, as long as a fluid is on it- alcohol, water, mineral spirits etc it’s invisible but as soon as it dries bam they’re back.
Won't Scotch brite scratch the he l l out of it?
No. It just dulls it. I used it on the rear bumper pieces before I used the Cerakote on them. Here’s a hood piece after scotchbrite and the bumper part after scotchbrite and Cerakote. View attachment 347256View attachment 347255
Ok, that makes sense. There's different scotch brite pads--green, red, white etc. I've never used a fine scotch brite, I usually use red or green which are pretty course.
Slo1
