rookie mistake: need help
udownwitk
i just got a optima battery for the '07 yukon for $100. without thinking, i turned it the way the old battery was facing therefore hooking the battery cables backwards. i heard something pop that sounded like a fuse but i dont know where to look. is the the 175 amp fuse in the "fuse block" thing on the firewall? i've only had this yukon a couple months, i dont even know where all the fuse panels are yet... any help would be greatly appreciated. thank you!!
Donnie Yukonie
Yates Caretaker
Uh Oh , You might have fried the ECM ... Check All the fuses you may have got lucky . Does it start or attempt to do anything when the key is turned?
U
udownwitk
it doesnt do anything when they keyed is turned. no power to anything far as i can tell.
Donnie Yukonie
Yates Caretaker
Hopefully someone chimes in On the location On ALL the Fuses . I hope you didnt fry it
U
udownwitk
yes, it was the 175 amp fuse on the firewall. replaced it and all is good!!
TxDrewski
Potomac,MT
Man I know your gonna hate this... But,
I did the EXACT same thing on my 96. Actually, my best friend hooked the battery up, but yeah... Backwards and it was a Red Top Optima... You could turn the key and NADA. No click, no nothing. It was the computer. Id advise you run down to an auto parts store and get a Chilton or Haynes Manuel... Sorry to hear about that bud that really blows chunks.
Haha nice! I couldnt see your last post musta been right as I was posting. Atleast you fixed it!!
KMeloney
Didn't Haynes Manuel play for the Phillies in the late '70s?
(You probably meant "manual." ;))
Gzes
the drifting 2dr
Wichita tx
Wow glad it was a fuse n not pcm. That would have been a expensive repair..
