Started cleaning sludged engine
J
Jon Chimpo
AC Delco oil sensor ordered along with 2 new knock sensors with the harness. going to rent the fuel line flairing kit so I can cut off the old fitting, and put a new one on.
NGAneer
NWGA
Wow man. Glad you're getting in cleaned out but that's a heck of a lot of sludge. How did you come to find out it was sludged?
J
Jon Chimpo
I did an oil change, and the filter was completely filled with sludge. That's when the fun all started.
afpj
Would seafoam be of any use for this situation?
J
Jon Chimpo
That's what I'm going to use after my oil and 1qt ATF flush. I'm going to drain the aft/ oil out after a 30min idle, pull the filter. then full back up with oil, and seafoam with new filter drive it for a while, then flush again.
we'll see what happens...
I'm really hoping this works out for you. You're doing a really good job. This is only more proof that these engines can run good, even after being abused and or neglected. Great job man! :waytogo:
J
Jon Chimpo
2 new knock sensors, the harness, and an Delco oil sensor. Another 230$ into this B.
J
Jon Chimpo
Thanks Tony, but it's not started yet. there will be prayers made to have this engine come back. My wife thinks it's going to work, I don't. Don't get me wrong, I really don't want to spend another 3k on this Z71.
Milooo
