Started cleaning sludged engine
J
Jon Chimpo
Im going with no. You ever seen an engine tore down that was neglected, especially with oil changes never or rarely done? The bearings end up with all kinds of crap imbedded into the shells. Mains, Cam and Rod bearings all are trashed. Ive seen rod bearings where the top layer was missing in patches because of crap in the oil.
this could turn out to be a half a million mile engine. should we start a betting pool on how long it will last? winner buys me a motor.
Tacky
When you get this running, keep a close eye on your coolant. A lot of the time when you have heavy sludge it s because coolant s getting into the oil.
BeenChevy
Minnesota
If you haven't gotten back to the fuel filter. I've had good luck saturating my nuts with water and letting them sit for 10 minutes to reactivate the rust.. then hit each nut with a punch tool and they'll break free. Repeat the process until you throw up.. but seriously water works better then the penetrating oils in these circumstances. If you've already dressed with a PO hit it with de-greaser first remove the oil and then apply the water.
J
Jon Chimpo
If you haven't gotten back to the fuel filter. I've had good luck saturating my nuts with water and letting them sit for 10 minutes to reactivate the rust.. then hit each nut with a punch tool and they'll break free. Repeat the process until you throw up.. but seriously water works better then the penetrating oils in these circumstances. If you've already dressed with a PO hit it with de-greaser first remove the oil and then apply the water.[/QUOTE
Really? I put this on the back burner for now. I'll give it a shot, as with everything else with this Tahoe, i have nothing to loose but my time.
DunzoDenali
