Stuffed 35 12.5's with only 2.5/1 spacer lift
Mighty Hd
Florida
How about some pics where you trimmed? I bet that thing is a slug off the line with the factor gearing though........ :-(
Z1500
Z1500
I'm lucky enough to have the factory 4.10's so it's not bad at all. Lost a little spunk for sure but going to turbo it anyway.
I got the Spohn adjustable rear control arms that I'll put on in the next week or two. Assuming I can space the rear axle back 0.5-1.0" then trimming plastic to the rear seems easy enough.
Now what's going through my mind a lot is how I could space the front 'axle' so to speak, forward an inch. If someone made upper and lower A-arms that just had the ball joints forward an inch, it would be amazing.
Zed 71
Pacific NW
For the front have to tried to adjust the camber to the + side?
AppocAlexx
Darth Appocalexx
Abilene TX
@Z1500 I feel bad bringing up all these old posts but I have to ask what your measurements are at the fenders. I'm looking at doing almost the exact set up but I'm thinking I may have a tad bit more clearance up front that you with my set up.
Z1500
Z1500
No problem. Where exactly would you like me to measure from and to?
Torrance1978
