Subwoofer remote control knob
Unit171
NC
If you have no bass.... do you still have your factory sub hitting notes?
Is your aftermarket sub not hitting? Do you have a remote control for your LC or aftermarket amp?
Q
Qlassic418
I thought with the lc2i there was no need for the 12v and ground because of the gto technology that is turning it on
Q
Qlassic418
I have power to my lc2i
The factory sub still hitting
But my aftermarket doesn’t
Unit171
NC
Good, what was wrong? And I just went and did my remote control knob with pictures for you.
Unit171
NC
Here are my two controls. Blue is the amp punch and yellow is my LC2i
E2B31D1E-DE10-4775-92B9-949B56C22722.jpeg C2D722A8-B72B-46A8-B961-F800FF630AF2.jpeg
Unit171
NC
Here is the under side of how I did it. First I took the LC2i control apart. 2 screws.... then loosened the nut and removed the chip/LED/control. I used the face of the control housing to mark my holes and simply drilled them out. Once drilled and cleaned, I put the chip/control in place and used the nut to hold it in place from the front.
6553673D-E06E-463A-AB86-98DC1E1DD8E6.jpeg 8BCC8352-F8E8-4ADB-8625-0A6D8E94AD75.jpeg
dylanrog24
