Tahoe Side Mirror MOD
chip
Tampa
Chip, did you look @ the Muth mirror website?
I already had the instructions from the website. I didn't print all of them out though. I got it figured out. Thanks!
For anybody who wants to know, Left/Driver's side blinker wire is Light Blue and can be found in the wire run that comes out of the back of the inside/drivers side fuse box. Same deal for the passenger/right side, only the wire color is Dark Blue. You can ground anywhere.
chip
Tampa
So what did you do exactly?
SHIT! I thouhgt that might happen. I'm trying to hurry to bed, but I'll go out there real quick. Hold on................
.............okay:
dgould
LED with out them blinking
chip
Tampa
Really sweet and creative mod! Will definitely try it out.
It's a cool, cheap and easy mod.
My above links are dead, but here you go:
Video here:
I did that under $15 and under 30 minutes.
Perfect sync. Very bright.
JesusArTorres
Tulsa, OK
Is there a thread or something on how to take the side mirror off in order to do this?
Do I just connect the LED wires to the turn signal wires? The Yukon has the turn signal in the mirror.
---------- Post added at 02:10 PM ---------- Previous post was at 02:08 PM ----------
Also, this is how the mirror looks. Pretty snug in there. Do you think it'll work? Te light will shine through?
chip
Tampa
Yeah, there's a thread about it around here somewhere. You're going to be using side emitting LED strips, which are really thin (you can get them on eBay cheap).
First: you take the entire mirror off, then you pop out the glass (it's held in by clips). Clean the surface really well. Apply the LED strips (they should have a "peel and stick" backing on them). Once done: Reassemble in reverse order. Tap the LEDs into the turn signal wiring - which is really simple, because the wiring is right there (under the dash), but I can't remember which wire/color/etc.
That's pretty much all the steps.
If you can find the correct wiring, you're go to go.
traveler613
