sorry should say compressor.Oil pressure sounds good. AC condenser is NOT "bottom passenger side". Its in front of the radiator. Looks like a radiator but slightly smaller and thinner.
I would check your universal joints. That is a classic description of one that is dry and that may fail.So i just got a 02 Denali and have been fixing a few issues. My drive way has a steep incline. When i pull up my drive i hear this ticking noise. It sounds like it is coming from the bottom passenger side like where the ac condenser is. i have not heard it any other time. Any ideas? It has 185000 miles on it.
This might sound dumb but should the u joints be moving if the truck ain't moving?I would check your universal joints. That is a classic description of one that is dry and that may fail.
Nope. Lets clarify. You dont get the ticking sound when the vehicle is in park and idling?This might sound dumb but should the u joints be moving if the truck ain't moving?
This sound is when the front end is higher than the rear only. it can be parked or driving. It does change speed with the engine. As I have talked with you guys I have noticed when it happens. I first noticed it when I was parked in my driveway.Nope. Lets clarify. You dont get the ticking sound when the vehicle is in park and idling?
Sounds alot like an oil starved bearing, lifter, valve but oil pressure seems good to go. I cant imagine a condition that would cause one to be starved when fornt is higher than the rear unless it were very extreme. Does it ALWAYS make the sound when the front end is higher than the rear regardless if at idle or moving? Can you get us some audio of the ticking?This sound is when the front end is higher than the rear only. it can be parked or driving. It does change speed with the engine. As I have talked with you guys I have noticed when it happens. I first noticed it when I was parked in my driveway.
