adventurenali92
Yes sir! That is correct!So just making sure I'm reading the posts on all these correctly, the tow/haul button will work, but the +/- shifter button will not.
Unfortunately, if you test the wires coming off the + - buttons with a multimeter you’ll see they have 2 different resistive values depending on if you press the + or - button. I didnt see a way to open up the shifter and remove the internal circuit either, so finding a use for the buttons is a challenge.hummm... ideas spanning from the unused shifter buttons that are resistive input. bet a couple extra buttons come in handy
haha I second that now I'd like to see pics of harness. are u guys using just a 07-14 shifter from nnbs I see the ones with and without buttons
I should be able to use resistance differences as button inputs to my car computerUnfortunately, if you test the wires coming off the + - buttons with a multimeter you’ll see they have 2 different resistive values depending on if you press the + or - button. I didnt see a way to open up the shifter and remove the internal circuit either, so finding a use for the buttons is a challenge.
Maybe someone with a turbo NBS 'Hoe can find a way to turn it into a boost controllerCorrect.
Thx. Gotta drive it to get the feel of it.Sweet NNBS shifter man. Nice work.
