Track times
renaldo99
Ok for my first time going to the track on stock tires and a half tank of gas i ran my tahoe 6 times and got these #s
2wd runs
1st run 1/8 [email protected] 1/4 [email protected]
2nd run 1/8 [email protected] 1/4 13.328@103
4wd runs
2nd run 1/8 [email protected] 1/4 [email protected]
3rd run 1/4 13.199@? forgot to pick up slip but was told i ran this
kinda dissapointed with my times i was really thinking i was gonna get high 12's..
just wanna know what i can do to get better times ????
2 E L O
Omaha, NE
DA = density altitude.
Given your ETs, trap speeds, and consistency it doesn't look like you were having wheel spin issues.
What were your 60' times? What gear/rpm were you trapping? Steeper gears and slicks would be the first things I'd change to improve your performance.... 3.42s are rather shallow.
renaldo99
renaldo99
2wd runs
1st run 1/8 [email protected] 1/4 [email protected] =reaction +.267 60ft1.981 594ft8.133
2nd run 1/8 [email protected] 1/4 13.328@103 =reaction +.501 60ft1.914 594ft8.054
4wd runs
1st run 1/8 [email protected] 1/4 [email protected]= reaction + .177 60ft1.858 594ft7.991
2nd run 1/8 [email protected] 1/4 [email protected] =reaction +.160 60ft1.840 594ft7.966
i was spinning on 2wd when i was launching@2000-2500rpms so i launched on no rmp build up and hooked with a lil slip... on my fist 4wd i launched at 3k and on my 2nd 2500
2 E L O
Omaha, NE
2wd runs
4wd runs
Pretty good for such a heavy truck!
What rpm and in what gear were you crossing the finish line? What size tires are you running? I'm guessing you were crossing the line pretty soon after hitting 3rd gear. If you're serious about racing you should swap your gears so you're crossing the line near the top of 3rd gear. This means at least 4.10s or possibly even 4.56s depending on your tire height.
renaldo99
renaldo99
i believe i have 225 55 r20 goodyear ls2 tires and idk what i was crossing at i have 3:42 gears
2 E L O
Omaha, NE
I assume you meant 255, not 225....
Anyway, 4.10s would help you drastically...but you'll need slicks to take full advantage of them... With a 4L60E transmission, 31" tires, and 4.10 gears you should cross the line at about 4,500 to 4,700rpm and you should cut at least 0.2 or 0.3 off your ETs...probably more.
Right now you're crossing the line at about 3,800 to 3,900 rpm in third.
A good approximation is that for every 0.1 second you can cut off your 60' time, you will drop 0.2 second off your ET. I think you could easily cut your 60' times down to the 1.75X range with 4.10s/slicks...
Good luck!
Also, drop any dead weight in the vehicle if possible. Another approximation is for every 100 lbs you shed, you'll cut 0.1 seconds from your ET.
You'd definitely be fine with 4.10s on the freeway. Right now you probably cruise at about 1945rpm at 75 mph with your 3.42s. With the 4.10s you'd cruise at 2330 rpm at 75 mph. No big deal at all....
gottaluv01tahoe
