Good catch. Nah, the sensor was bad. Eventually my cam bearings went bad in this motor--another one in the works thoDamn 80psi oil pressure
Okay I attached the little card that's in the glove box. I have to decipher it. In terms of the ride, I measured 33 1/4" between the rear fender and the ground, 32 7/8" from the front fender to the ground and approx 70" tall to the roof, not the rack.
I wonder if you're lowered at all. Seems a bit low.
I have the same ratio, it's a great compromise imo.
ZW7 Premium Smooth Ride and G65 Nivomat rear shocks. Unless they've been changed...
Bingo. Do you hear the compressor running? Do you have a "service ride control" message?
Shouldn't have a compressor with the Nivomats. They adjust manually with no external connections.
New cluster lights
I had my cluster repaired by someone on ebay, shipped it out to them in AZ i believe, they found several grounds, replaced the motors and also installed blue led's to replace each bulb. Took probably 2-3 weeks from shipping it out to getting it back. Only around $60-70 total.
Also for the rough shift 1-2 I had/have this issue as well. When cruising through my neighborhood at real low speeds my shift is delayed and clunky, where really getting on the throttle it shifts much quicker.
I brought the truck to a transmission guy in Jacksonville and he took a look and said its not the trans it is probably a motor issue for me. Anyways I had him go into it, he ended up replacing the boost valve to up the pressure and he said everything looked just fine. Wasn't really necessary but it is what it is.
I got a new TPS just on a hunch, but turns out I have to replace the entire throttle body because that sensor is riveted to the side. I got a reduced engine power one day, took off the throttle body and cleaned it, went away. Luckily I was already on this path so when the new throttle body came in a few days later I put it on and no issues. I also noticed my shifts had cleaned up a bunch, it felt much better.
Now I am battling a different weird issue, I get vibration at my pedals almost like my bearings are shot but they aren't. I am thinking motor mounts. My tahoe is also very clunky I think it is time to replace some other bushings and such.
