truck actting up!!!!
big kon
Hey !
Whats going on Im new to the site. My truck starts fine but its actting funny. Im having a electrial problem with my 1997 Gmc Yukon 2wd . I have day time running lights that or hid . They stay on for a min then gose off or one will stay on then gos off.So Ive been riding around with my high beems on for the last 6 , 7 months but the other day i get in the truck to go to work and the high beems go off. the high beems or not hids. So on top of all that when I start the truck most of the lights on the dash stay on airbag,hazerds lights, but they go in and out on the dash as i drive rev the engine. I had my music hooked up but when i would turn up the deck it would shut off then cut back on but if I turned the bass swith on and turn up the deck to 30 it will shut both the deck and amp off. All I have in the truck is a alarm, 1 amp, dubble din jvc deck, 2 12 l7 with 2 battarys. Can any one help my point me in to the right anything.
luv Big Kon
Thanks
B
big kon
jonathan might you no where to find the diagrams for the grounds or power feeds.
thanks!!
---------- Post added at 11:21 PM ---------- Previous post was at 11:20 PM ----------
Or anyone who can halp .
---------- Post added at 11:22 PM ---------- Previous post was at 11:21 PM ----------
help
SunlitComet
OBS Jedi-Do Good
unknown at this time.
GROUNDS LOCATION
G100 (VIN J, F) RH front of Intake Manifold
G101 Sheet Metal at RH front Wheelhouse
G102 RH front of Engine Block, near Damper Pulley
G103 RH front of Engine, near Thermostat Housing
G104 RH top of Cylinder Head, near center
G105 RH front of Engine Block
G107 LH front Fender (Auxiliary Battery Ground)
G110 RH rear of Engine Compartment, below Heater Lines Gill RH rear of Engine
G112 RH front of Engine Compartment, below Underhood Reel Lamp
G113 On Radiator Support, near LH Headlamp
G150 (VIN M, R, J) RH front of Engine, near Thermostat Housing
G200 Behind LH side of I/P, below Fuse Block
G201 Behind LH side of I/P, below Fuse Block
G400 RH "B" Pillar
G401 Rear of LH Framerail, behind Bumper
G403 Rear of Framerail, behind Bumper
G404 Inside LH Framerail, near rear Crossmember
G405 Frame Ground, at rear of vehicle
G410 LH Inside of Framerail, near rear Bumper
G451 At Platform Hitch
B
big kon
Thanks guys . So check this out i take the hid lights out and the deck and put stock lights in and stock deck and its working fine. the light or working not going out my dashs lights or of and the deck is staying on i turn it up no problem so what that mean..??? help help thats a trip. thanks
B
big kon
My bad .
I WAS SAYING THAT BY PUTTING EVERYTHING BACK STOCK IM NOT HAVING ANY PROBLEMS BUT I WONT THE LED LIGHTS , BIG BASS , DOUBLE DIN DECK BUT WHEN ALL THAT WAS HOOKED UP THE TRUCK WAS ACTTING UP.
Tssonebay
