Volant1
V
Volant1
Volant guy
Upland, CA
Ill see what I can do for you, Those are 24" SAF wheels with a custom cut offset to clear the bear brakes kit
---------- Post added at 02:24 PM ---------- Previous post was at 02:20 PM ----------
Will do!
x2 on the fitment. I can't the Hole in the box to bolt onto the Hole on the inner fender where the stock box use to hook up.
Also I still don;t know where the Rubber Linings go either!
Is this the 96-99 body style? the trim sponges go around the box where the air duct goes through and around the box where the box meets the fender, The Volant box hole is larger than the OEM
WINGMAN0711
