What DEF Fluid?
JayceeP
Anyone have any suggestions on the “best” DEF to use? I read the manual… doesn’t say much aside from meeting the noted standards. Get it from the dealer or any automotive store?
This is my first diesel (2024 Yukon XL SLT) and DEF level is at 50% after 3,000km (2,000mi). Seems a bit heavy on the consumption but assuming that’s just break-in consumption and definitely some shorter trips in the mix.
Thanks!
UsualSuspect
SoCal
Truck stop DEF from the pump. The stuff has a shelf life. Rule of thumb I operate on, never let it go below 1/2 a tank. My mechanic told me years ago to always stay above a 1/2, if you get bad DEF, it will be diluted enough with the good that is there and you should be ok, and worse case you will make it to a dealer. We have had a few tow in's from bad DEF, doesn't happen often, and all of them said they fill it when it's empty.
J
JayceeP
I bought a 2.5 gallon jug of Motomaster Blue DEF from Canadian Tire. My gauge said it was at 50% and it took the whole jug which would be half the def tanks capacity. The gauge now reads full. I know it’s not a perfectly accurate reading but good to see it’s in sync. On the flip side, seems like a lot of DEF consumption over 3200km/2,000miles.
Stbentoak
I prefer the Walmart DEF because each bottle has a date on it. I can usually get a jug that is less than a month old. I watch my Bank IDash and when I get below 50% I add another jug.
They go through skids of this stuff every week. You couldn't find an old bottle if you wanted to. A bonus to using this stuff is you get a great waste oil jug when you change your oil to take and recycle. Plus, you don't have to deal with pumps at stations that aren't maintained or are dirty. No downside to using Walmart stuff.
Jay P Wy
Natrona County WY
Also don't buy DEF from a store that stores the stuff in windows (usually auto parts stores). Two things that will degrade DEF are heat and sunlight. If you store jugs at home keep in a cool place away from sunlight (like a basement).
DaveL
Question that is not really about DEF. What do you think about your Bannks IDash and what are your favorite features?
I am waiting for the 2025 Tahoe with the new diesel and have been researching the IDash.
StephenPT
St. Helens, OR
There's a lot of things I like about it - in no particular order:
1) It shows me when I'm in a regen cycle. I never want to stop it in the middle of a regen - if I can avoid it. I know it's designed to handle it, but if I can take the long way home and let it finish its regen cycle, plus let the exhaust system cool down a bit, that will help extend the life of everything. It can't be good for the system to shut down at 1100F+ inside the DPF...
2) I like to see engine oil temp. This engine runs hot - the coolant is often in the 210F range and it's used to cool the engine oil in a stacked plate cooler mounted to the side of the engine. Hot coolant means there's less delta T between the two fluids so therefore engine oil stays hot. I see oil temps at ~220F unloaded and above 250F most of the time when I'm towing. I saw 260F once, but then promptly saw the coolant plummet to 185F so that must be a threshold programmed into the ECM.
3) I get to see what gear I'm in. It's amazing how little this engine needs to downshift to go up inclines. A testament to how well this engine produces bottom end torque.
4) DEF level is a percentage and not a little chiclet on the dash info screen. As previously mentioned, once it's at 50% I dump in another jug.
5) Multiple pages for different configurations. I have one page setup for everyday driving - the other page setup for towing. You can have up to 5 pages configured.
6) Last but not least - I like its profile/size. I don't want a mini-tablet on my a-pillar. The IDash has a clean look, easy to read and is a subtle addition to my dash layout. My wife does not like clutter and this doesn't bother her in the least bit.
drackill1
