Speed Engineering isn't any help? Seems they're responsible for their y-pipe being in the way.
Not really. All they said is no one has ever had a problem, and if there was a problem, it would be my motor mounts. My motor mounts are fine. Two different mechanics checked them. They also said if it didn't fit right to just return it. Really? Great, I would if it wasn't already on and I actually need it to drive the damn truck! Sooooo helpful.
massivespl
I'm not mean, I'm honest.
Michigan
Did you get a fuse holder. And what did you use for terminals- solder or crimp only?
U don't have to run a fuse. I don't fuse anything in my truck. Some people do andnsome don't. My factory power wire doesn't have a fuse on it from the factory that way.
95escahoe
Went to a driveshaft place, who said they can't do much until I do something with the y pipe. If I was able to fix or move the y, they'd build a custom shaft, which would be thinner, but just as thick walled, using my old part that goes into the transfer case(forgot what it's called) for what I consider a reasonable price. But that damn y pipe! It's in the way of the prop shaft, along with a header tube. I go to one exhaust place who wasn't any help at all. This is what I'm working with. View attachment 74821Almost hits the tube, and once the shaft is in, the universal will def hit the tube, so it would need to be dimpled. View attachment 74822Can't really tell from this pic, but the y is at least 1 1/2" over the dip in the cross member for the prop shaft. Just plain tight, and I don't want to squash the y, what would've been the sense of getting it if I did that! Defeats the purpose Imo. View attachment 74824Just so damn tight. View attachment 74825
How did yours compare to that guy with the Escalade that ran the same kit? His seemed to work just a tight fit
TheAutumnWind
Its a fusible link. So yeah there is a fuse. Is it 100% necessary? I suppose not, but I chose to spend the extra $10 for a fuse. Seems like cheap insurance in case it grounds out against something.
TheAutumnWind
I'd get an ANL fuse holder. I ran this: but didnt love it becuase the cover was kind of loose.
https://www.amazon.com/gp/product/B00FSKYNSC/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
The knuconcepts one looks nice:
https://www.amazon.com/KnuKonceptz-...=1487394279&sr=1-8&keywords=1/0+anl+fuse&th=1
I only crimped. With the hydraulic crimper that I posted awhile back its very solid. Basically a cold weld, no way those things are coming off, and excellent contact. Definitely recommend going that route.
Brice25
