dnt1010
Tennessee
2009 Tahoe Hybrid 4x4 (recently acquired) It is high mileage so my plan was to change all fluids. I changed the front differential gear oil yesterday. Manual called for SAE 80W-90 Axle Lubricant GM Part No. U.S. 89021671 for the front. I used a Valvoline 80W90 Gear Oil Part No VV831. Now I am second guessing my choice of fluid.......The more that I research the more that I get confused.
I am wanting to change the Rear differential fluid also the owners manual calls for SAE 75W-90 Synthetic Axle Lubricant GM Part NO. U.S 89021677 I had picked up some Mobile1 SAE 75W-90 Synthetic LS for the rear. Now I am afraid to use it since it is marked LS (I assume that stands for Limited Slip?) and the G80 axle does not use the LS additive or at least that is what some internet articles say. I never thought it was that big of a deal but maybe it really is? Sigh nothing is ever easy. I may just pony up the cash and order the GM stuff.
bottomline2000
Dallas, TX
So when I replace my autoride shocks with regular generic shocks I'll lose an inch or 2 ?
yes, if you have the stock nivomats, but if you change springs at the same time you won't notice a difference.
Once again, that's for the rear. Still won't affect alignment which is what we were talking about. But yes, any time either Premium Z55 or Nivomat (forget RPO code) rear shocks are replaced it's recommended to change the springs to Z71 or similar. I've heard from some who say they have changed to regular shocks without changing springs and there's no difference, and some who have had a soft mushy ride after. I like having the self leveling myself, especially with bigger wheels and towing.
yeah, i was just talking about shocks vs springs on some of our trucks. it still wouldn't change alignment. I liked my nivomats because my truck had more load capacity, but it rode best when pulling a trailer and i rarely did that so they had to go.
bottomline2000
Dallas, TX
my truck had them nivomat shocks. they were shot to hell. i put bilstiens in place of them, dont ya know, my ride height did not change one bit.
now holding extra weight i could see them help out with. but they are still not lifting the truck up one bit.
i added a pair of air bags to help with towing or hauling weight.
i guess it depends on how your truck was originally equipped. no way in hell i could compress my nivomat shocks as they were completely stiff. I could feel the shocks ratchet up when loaded and with each movement the shocks would compensate for the load. i still had my original springs and my Bilstein shocks bottomed out if i went over any road with big bumps so it was very obvious the Nivomat shocks shared the load, maybe yours were replaced or you sagging and don't know it lol.
Just a fyi-
In place of conventional shock absorbers, this unique system is installed on the rear axle. While providing additional roll stability without requiring any additional electronics, the Nivomat adjusts the vehicle to the optimum ride height for every load condition, thus ensuring a safe and comfortable ride.
The Nivomat system does more than just level the vehicle under load. As the load increases, the pressure inside the shock increases as oil is displaced from the reservoir to the inside of the unit, compressing the gas volume. This creates a progressive increase in spring rate and damping with little or no change to ride frequency.
bottomline2000
Dallas, TX
looks like the rest, like it needs a leveling kit lol
Yeah, yours is an LT so maybe it was equipped differently. Mine is a LS with SLE pkg. Technically my truck should be stripped, but I have a tow pkg tow hooks, leather interior, for lights and body side molding including painted bumper cap. Only my mirrors are black. GM did strange things back then.
Sent from my SAMSUNG-SM-T377A using Tapatalk
bottomline2000
Dallas, TX
Yeah, yours is an LT so maybe it was equipped differently. Mine is a LS with SLE pkg. Technically my truck should be stripped, but I have a tow pkg tow hooks, leather interior, fog lights and body side molding including painted bumper cap. Only my mirrors are black. GM did strange things back then.
ScottyBoy
Shreveport, La
Got in my truck this morning and cut my arm. Didn't know what it was but then I saw this.... not happy
Also saw a big oil stain in my car port. Hopefully it's an easy fix
Any idea where I can get the back leather and foam?
Go check out "TheSeatShop" they have factory replacement seat covers for a few hundred dollars. As far as the foam, they have the lower foam but not the back. If you feel the metal seat frame near the arm rest (around the bottom of where your rip is) then that's probably normal as mine is the same.
https://www.theseatshop.com/2004-gm...&groupIds=3,7042&seatRowId=6&seatPositionId=9
clublub69
