What console is this? Never seen one. It's not the Regency or Southern Comfort one either. Their door panels are also different. It's in an 02 with 114k for sale locally for $3k, but there's no external body cladding or mods
full
If it wasn't for that cup holder, I'd think the center console was from a ford. It might've been a regional package--what a local dealer had installed. Try running the vin?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
TRUCK MAY NOT HAVE CAME WITH A CENTER CONSOLE, SO THEY EITHER MADE ONE OR MADE ONE FIT IN THAT LOCATION.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
That list is getting shorter lol. .
Sent from my SAMSUNG-SM-T377A using Tapatalk
Haha... yeah kinda... except I have to add hub assemblies to the list now. Thought my wife's brakes were squeeling so I bought a set of pads and took the wheels off... plenty of meat on the pads so I took off the calipers and rotor. Turns out, the noise is coming from the bearing. Yippie.
full
Seeing as there's ALSO wood trim plates for the dash bezel, switch bezel, and the steering wheel, I'd guess it's a Mark III or Choo Choo customs conversion... which would make that a custom center console proprietary to whichever cusomizer built it.
Sam Harris
Texas
Haven’t had much time to do crap to the ol girl lately but one thing that had to get done was replace the audio jack for my phone that’s tapped into my XM receiver. Came across a pair of skull candy blue tooth headphones I though I lost and thought what the hell... well it flippin worked. I successfully hooked the Bluetooth up to the XM receiver. Now I have blue tooth in my hoe. Works like a charm and couldn’t be happier!
I need to do this! Can’t tell from your picture, but I don’t have any aux jack on my head unit (‘03 Yukon SLT, w / Bose system) I really want to add Bluetooth, but don’t really want to replace the head unit. Can you post a little more detail how to do this? Do you have the stock XM head unit?
Sam Harris
Texas
I was looking under the hood today, mapping out location for my catch can on order. Was planning to attach the bracket to the master cylinder, but was pleasantly surprised to find this. I believe this means I have factory hydroboost?
full
someone added that, it's pretty similar to ones used on government vehicles or ppv/ssv, makes it so you can add radio's, switches, etc
HiHoeSilver
Away!
Chicago
Looks different than mine. Do you have JH2 in your RPO list in the glove box?
latvius
Ariton Alabama
Ordered my replacement transmission from CahallperformanceTransmissions. This is one of those "I have faith" moments.
Performance
Toledo paper and rubber kit
National front seal
Front seal retainer
National tail seal (Except 4x4)
Sealed Power filter
Farpak pan gasket
Babbit hook style pump bushing (don’t fall out like Teflon does)
Bronze case bushing
Bronze front sun gear bushings
TG .500” boost valve kit
Hardened pump rings
Borg Warner 29 element input sprag
Borg Warner 4L65E low/reverse sprag
“The Beast” sun shell
“Corvette” 2ND servo
New aluminum 2ND, 4TH, and input accumulator pistons
Borg Warner Hi Energy 2-4 band
Borg Warner 3-4, forward, over run, reverse input, and low/reverse frictions
Raybestos steels
Heavy duty rear ring gear snap ring
CPT shift kit
New pressure solenoid, shift solenoids, and pressure switch manifold.
Sam Harris
Texas
I do not have JH2 in the list.. hmm. Any other codes for it? I assumed that’s what it was, mostly due to location. If it’s not hydroboost, I wonder what it is.? I’ll post the codes in my glovebox, sorry for the crummy picture quality:
66AF60CC-7BBF-4E74-A95F-AC52CC65710F.jpeg 2C79EF64-16BF-4E01-BC39-227D03B3B4A9.jpeg
Levi0320
