Scottydoggs
NJ
i see a booster behind the master. hydro booster is a metal block, you dont see the big round black booster with a vac line/hose to it with hydro boost. you also have p/s lines running to the hydro boost.
Massfloefi
Installed Eibach sway bars today. Just a few shots for comparison.
Stock rear sway bar slightly taller.
Thickness comparison. Only slightly larger and weight seemed the same.
Front sway bar.
Height comparison to stock.
Thickness comparison. This was noticeably bigger and heavier.
Massfloefi
So what do I think of them? If you're a spirited driver I think these are a must have. The truck goes were I point it, finally. Changing lanes with the stock sway bars at high and even low speeds felt boaty and unsure. At high speed cutting in and out of traffic would feel down right dangerous sometimes. Another noticeable benefit is at slow speeds when going around a corner. The truck doesn't lean nearly as much and I don't have to crawl anymore.
Now do I think they are worth $500 as an upgrade? NOPE, but I think they were worth it at the $300 I paid. I would be curious to know how much better the solid Hellwigs sway bars are. Honestly can they be worth double what I paid?
I personally think If your gonna spend between $470-$600 on a suspension upgrade your better off spending a little more on a coil over conversion. The handling from what I hear is better and so is the comfort. Plus your dumping a 40lbs sway bar setup.
Just my opinion.
@HiHoeSilver @M3kanic
Now do I think they are worth $500 as an upgrade. NOPE, but I think they were worth it at the $300 I paid. I would be curious to know how much better the solid Hellwigs sway bars are. Honestly can they be worth double what I paid?
Just my opinion.
Just curious--did you use poly replacement bushings? I'm guessing you probably did:D
Massfloefi
Yes I did as they were supplied with them and the front sway bar came with new links. I believe those are poly as well.
drowssap
Colorado
I have the Belltechs front and rear to install on my Yukon....I think I read they were the equivalents to the Eibachs. Could be wrong! Do you happen to know if there is a difference other than color?
Massfloefi
This is what I found. If summits sizes are correct. Not sure about weights.
Eibach
Front 35mm
Rear 32mm
Belltech
Front 36mm
Rear 30mm
Levi0320
