That's what I did, but my state does a visual. #OUTLAWIf you don't need cats to pass visual inspection, just get a catless Y-pipe and have your tuner turn off the rear O2s when they tune for the cam.
Effin Jersey....That's what I did, but my state does a visual. #OUTLAW
Agreed!Effin Jersey....![]()
You can get y pipes with cats or without cats from most of the bigger name header manufacturers. The pre cat (upstream) O2 sensors are what your ecm uses for tuning purposes and those stay regardless if you have cats or not. The post cat (downstream) sensors are what the ecm uses to monitor cat performance and you can eliminate them physically and then have them tuned out or use spoofs like antifoulers. If you end up with cats it’s best to have the downstream sensors. On a side note some emissions places have visual inspections that look for cats and will fail you if they’re not there but some people install things that look like cats. My state doesn’t do a visual, they just hook up to the obd port and since my O2 sensors are tuned out everything passes.
@Bombsquad85 just posted a video of his Denali running without cats. His is a 6.0, but you should listen to it, just to get an idea.There are not inspection required in Illinois (at least in my county) so I think I'd be ok without them, but I worry that removing the cats will give me a raspier tone and make it considerably louder.
I had intended on removing rear O2 sensors since they won't be needed after the tune is done. I guess I'm just second guessing myself at this point and making sure I'm doing the correct thing for my project.
Oh yeah I forgot about that. He has a stock exhaust though but you get the idea. You can always quiet things down with a muffler when running headers if it's too loud.@Bombsquad85 just posted a video of his Denali running without cats. His is a 6.0, but you should listen to it, just to get an idea.
Yeah, just like mineOh yeah I forgot about that. He has a stock exhaust though but you get the idea. You can always quiet things down with a muffler when running headers if it's too loud.
you have a air leak on the intake manifold(seals can go bad)..
( you can hear it more in the center, then when the camera is on the pass side area )
or connection to the intake I would inspect every hose .. use something flammable like Axe just only use tiny squirts that stuff has Propane ..you can find the vacuum leak with that just do it on a cold engine
have a ABC rated fire extinguisher on hand just in case..
o
o
