blueinkd
Did the same job bout 5 weeks ago. Sits well below the 200* mark now. I noticed the upper rad hose pipe was starting to get a bit wet around the joint where it slips into pump housing. Replaced all hoses and Ts also
Woodblocker55
My 2006 gmc yukon xl runs at about 206f all the time .. It got new radiator hoses etc thermostats ,tranny lines etc ..I even changed antifreeze sensor temp.. still right at 206 f but sensors right on the head on passenger side front..
Sent from my LGL722DL using Tapatalk
mattbta
Frisco, TX
Ended up having to take quite a bit out to get to it. Also ordered a pass-thru 1/4" set which was the only way I could manage to get a socket on those two sumbitches! Got everything reassembled except for the dash cover and passenger vents. Notice I apparently wasn't gentle enough with the cover and cracked the plastic under the metal mounting clip at the corner end. Going to attempt a JB Weld repair so need to do that and let it cure.
Started it up and let it run its calibration. Seems ok...will test drive later!
Matthew Jeschke
Sahuarita, Arizona
View attachment 261735 View attachment 261736
I too had problems first time with those dumb clips by windshield. acutally JB welded crap out of my cover to reinforce them.
Sent from my SM-A505U using Tapatalk
Chadly14
