mwilson62000
- Joined
- Jan 20, 2015
- Posts
- 428
- Reaction score
- 1,404
Wouldn't hurt to also inspect the wiring and the connector at the TPS. Try the old unplug, spray down with electrical contact cleaner, plug back in trick.Got this code yesterday. Cleared it and it hasn't come back yet. Now I wonder if it is the battery slowly giving up the ghost. View attachment 365715
This code goes along with that evap code, and another code I've never gotten before either. I replaced that tps connector and a length of the pigtail a few years ago. They're known to get breaks in the copper inside the insulation--which could cause the "Reduced Engine Power" cel.Wouldn't hurt to also inspect the wiring and the connector at the TPS. Try the old unplug, spray down with electrical contact cleaner, plug back in trick.
Maybe, repeat that process a couple of times to ensure the contacts and connectors are "scrubbed" clean by working them on and off and hosing out crud with the spray... Could be road-salt corrosion or road grime in the pin connectors interfering with just enough current to throw a code.
Oh man. Nice little project. Get closer to Houston so I can look at this thing!! I been meaning to ask you about the transmission cooler you added. I want to so the same to mine as I have noticed during cooler Temps the minor 1-2 jerk has not been present. I want to add the cooler before texas heat rolls back in.I need help.. I spoke with Performabuilt regarding my transmission upgrade.. I’ll be ordering the level 3, and a 2800 stall TC.. that part was easy..
Next, I want a cam and heads. I’d also like to do the intake, and already have the NNBS intake in storage.
I want a fairly good chop in the cam, so expect that’s pretty easy to accomplish with the correct lsa around 112 or so, but I also want the best low end torque I can get with the stock 5.3. Not necessarily the best top end.
Looking at the TSP PRC head and cam packages, I think this would be a good way to go, and take some of the guesswork out of it. However, even looking at the packages, there are a lot of options..
stainless valves / hollow stem valves / inconel.?
Chamber size? 68cc is standard and I expect I want to stick with this, to avoid and milling, rather than sending brand new heads off to the machine shop.
Pushrod length: defaults to 7.475 I’m assuming that’s factory length. No idea if I’d need a different size until cam is in and heads are on.
Cam: looking at Stage 3 truck 216/220, .600”/.600” (112 lsa)
Timing chain: I think this is wise to replace, but I have no idea what to go with for the replacement. Lot of options..
Oil pump: I think this is also wise to replace, and don’t think there’s any need for higher pressure, but higher volume may be desirable.. so thinking the Melling HV pump.
Rocker arm trunnion upgrade: I definitely want to upgrade these but TSP kits are back ordered..
Any advice is very much appreciated
I also need to determine what is involved and part list what I need to swap the existing intake, for the NNBS intake. Money is less of an object at the moment, than time.
ETA: Any other supporting mods that I haven't listed here will certainly be appreciated, and entertained..
Smith Brothers for the trunion upgrade is what I used for both mine except I ended up throwing Yella Terra full roller rockers on my Denali later ($$$ for those lol).I need help.. I spoke with Performabuilt regarding my transmission upgrade.. I’ll be ordering the level 3, and a 2800 stall TC.. that part was easy..
I should be migrating to near Ft. Worth around June.Oh man. Nice little project. Get closer to Houston so I can look at this thing!! I been meaning to ask you about the transmission cooler you added. I want to so the same to mine as I have noticed during cooler Temps the minor 1-2 jerk has not been present. I want to add the cooler before texas heat rolls back in.
I should be migrating to near Ft. Worth around June.![]()
