Sam Harris
Thanks brother. It's been a while since I updated it!First off- I like the new avatar.
Tighter LSA leads to low-end torque as well as chop.
None of this is really necessary at this level. You're not revving high enough to really benefit from the exotic stuff. Stock valves are fine.
Does PRC build the heads in these packages to suit? I'd recommend getting SCR to ~10.5 or higher. If 87 is a must, maybe at least 9.5-9.75ish? So, whatever chamber size will accomplish this but not put your PTV in danger. If you want thinner head gaskets as part of the equation, I think Fel-Pro has .045" for about the same price as OEM. I saw this long AFTER I ordered $80 Cometics.
That's seems really long. Stock length is 7.385", but most round it to 7.400" for some reason. Performance cams often, if not always have a .050" smaller base circle, requiring a .025" longer rod. Any other changes from stock (heads, gaskets, etc.) will alter the rod length. A 7.400" rod is the general standard for cammed engines to maintain stock lifter preload.
Are those PRC heads made from virgin blanks or are they reworked stock heads?
Will definitely chop and have good low-end and certainly top-end. You're covered with the converter. Gear ratios are a considerable factor- whatcha got?
Can't go wrong with the OEM "HD" LS2 chain. GM uses it in their GMPP line and it's the standard in the Gen4 engine. I believe the part number is 12646386.
If your current pressures are fine, a new OEM pump (which could be Melling) will be fine. If it wouldn't hurt to have a few more PSI, get it from more volume. Look into the Melling M295 or M295HV. I got the HV for mine and I'm pretty sure your Gen3 would take the same.
The RPMSpeed Max Effort kit would be my choice. I'm not totally convinced on the bronze bushing kits. If I were to try them, I'd get CHE.
I'm pretty sure your '03 is a three-bolt TB, yeah? That's a changeover year- is your TB cable-driven or drive-by-wire? Besides the TB, the injector size and plugs are the only other possibly mismatch I can think of.
Re: LSA: Nice.. I think 112 will be good then..
Stock / Stainless valves are good.. Awesome..
Yes, I can order a number of different options, or build to suit. They do have a handy compression calculator, but it's tough being clueless.. I know I can use a thinner head gasket to bump compression a bit, but I don't know if I can really get all this figured out until some of these things are in place.. Thanks much for the tip on the Fel-pro..!
The heads are new -cast, and this is one of the things I'm trying to decide on. (though they do have a package with customer supplied heads as well) As-cast vs aftermarket casting? Not sure what that means. I think a ported head would be the best option... Here's one that I thought might me a good fit: https://www.texas-speed.com/p-8013-prc-15-degree-220cc-cnc-cathedral-heads-cam-package.aspx however, I also don't know what would be a good choice for cc volume.. 220 all the way up to 247cc..?
Timing chain: I figure between your and Mark's recommendations, I'll probably go with a single roller Cloyes.. Of course that still leaves Z06 or C5R. I guess the Z06 will do fine there.. less expensive..
Melling HV is the plan. I will do this..
Pretty sure the TB is a 3-bolt. I removed it about 18 months ago, but don't remember. lol.. It is a DBW, and since I have Flex, I think I should be good there - hopefully.
Do I need cooler plugs..? If so, I think I'll need to look into a LSA, to justify the plugs..
ETA: Gears are 3.73..
