I am with these guys. My guess is that the side or spider gears are damaged. The good thing is, I don’t see G80 on the RPO which means that parts are not too expensive if the ring, pinion and bearings are ok. Time to pull the cover.
I wonder if it'll be cheaper to fix it or replace it totally.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
That depends on whats wrong. If you replace it yo will want to swap your brakes over. Hopefully you get one with good backing plates for the brakes or the axle shafts need to come out.
I would take the cover off and inspect after confirming the fill plug comes out.
Dorman makes two-piece backing plates that don’t require the axles to be removed in order to replace them. It’s one of the few parts made by them I actually recommend.
Walchit
Hopefully they're not Castech 862 heads. I think one on my van is cracked. Got a pic of the logo on them? Castech logo looks like a battery.
Unless I'm blind neither set I have are castech. I am willing to bet the 706 heads in the truck are, because I've seen a little moisture on the inside of the oil cap. Idk if that indicates castech problems for sure though.
I will take some pics of the heads here in a minute
If it's a little moisture, it could just be normal condensation.
Walchit
Gonna have to flip that driver side cover over. If it has the circle hole in the baffle, it's the older style. You're looking for a square hole.
Geez! Guess I'm still looking for a valve cover then, lol
@Tonyrodz no castech that I can see on these
Well, dammit.
You gonna do any work to them heads? They're actually a bit of an underdog and just need some mild porting and maybe some stock intake valves from the 799/243 heads. Good for low- to mid-range torque.
Rome58
